HI guys,
I am a web developer and I am looking for an updated program that can help me test my websites’ compatibility with the browsers of clients to enable me to focus on accommodating as many browsers as possible during the design process. This software should be able to check website browsers compatibility and enable me to view the differences in rendering for different browsers.
If anybody can help me on this please reply to the post.
Check website browsers and users
Hello Barbara
You can use Adobe Browser lab (free) which let’s you choose ever browser and operating system you wish to test. All from Mac IE6 to windows Firefox 5. Other good ones are Optimizely which has a free trial, Litmus with $49/month/user. These are all tools you can try out with your site.
Try to use the SortSite browser compatibility tests that Powermapper offer. This is just a one click website tool whereas you can check you website in one tool into different browsers. You can check the major and minor issues even the critical one. This tool can give an early warning or reminder of what particular browser can have a compatibility issue on your web site without using a different platform or testing in individually to a different browser. This will save your time to fix the issues that the tool will give you. All you have to sign up and download the software then enter the website address and wait for the result. You can also try the 30 day trial for free.
You may also check the Multi browser viewer which can display and analyze your website into multiple browser in a one tool only. You can also screenshot the images from the website whereas the tools find some issues. Try it free for a few days and if you are satisfied you can download the software on their website. You can also ask or help from the supporting group if you found some issues in installing or using the software.
