Check Your Data From One Phone On Another Using Sync Samsung Tablet With Samsung Mobile Device Sync Service.
how can we sync Samsung tablet devices with Samsung mobile? How does the sync process work between two mobile connected devices?
We can sync any mobile devices with any mobile devices. It is just like another sync process all we need is the software which will help to us to sync the two mobile device’s to do so with the Samsung devices we need a software name SIDE sync. Which we are going to use for the syncing process between two mobile devices like which we are going to perform with the Samsung tablet to Samsung mobile.
To all the sync process follow these steps:
Step 1: Go to google and download SIDE sync software.
Step 2: Install the software on both the devices.
Step 3: check whether the software is installed or nor in the device.
Step 4: Open the tablet can click on the app or the software which is installed named as SIDE sync.
Step 5: Do the same in the Samsung mobile phone also.
(Remember that the devices which you are trying to sync must be connected to the same network)
Step 6: It will scan for the devices which are present in that network.
Step 7: It will show you an option, what are all the devices present in that network which can sync with the particular device.
Step 8: Once we click on the device which is to be synced then it will take a few seconds and connect to the device and gets synced.
Step 9: once the device is synced with the mobile device then we can operate our phone even through the tablet.
Step 10: Remember to be on the same network to be connected to the same network to do the sync process.
In the case, your mobile device is connected to some other network and your tablet is connected to another network you can’t sync both the phones. To do the sync process in between the phones we need to stay on the same network.
So how does the sync process work in between the two mobile devices is like, when we have connected our phone with another phone which tablet to Samsung mobile. We can see all the functionality’s of our Samsung mobile within our tablet device itself we can do all the operation which want to do on the phone using the tablet without touching the mobile phone.
But while we are using the mobile phone through the tablet we need to make sure that the Samsung mobile or any device is connected to the same network else it will stop functioning.
To more about this process google SIDE sync and you can find about it.
