Checking of internet speed in nokia n8
I even want to check my internet speed in nokia n8 is there any kind of software to check my download speed?
Hi Ranjithchowdary,
Yes there are several sites & applications to check download speed of your internet via Nokia N8, and the good thing is these are all free of charge.
(A) SITES
Use your phone's Internet Browser (e.g. Opera):
http://www.dslreports.com/speedtest?jisok=1
http://www.n8fanclub.com/2013/01/cnlab-speedtest-130-signed-nokia-n8.html
Scroll down till you see this window, select your package and click Begin Test.
(B) APPLICATIONS
You may download the following applications:
(1) Internet Speed Tester
(2) SpeedConnect Connection Tester
(3) Download Speed Test
Hi Ranjith ,
You do not need any kind of software for testing the download speed in your mobile Nokia n8 comes with inbuilt connection manager where you can check the packets which are transferred . For checking the download speed go to the menu in the menu you can find settings option click on the settings option and click on the connectivity after you click the connectivity option you can find the option connection manager. Once you click on that option you can check the download speed of your phone.
