Chinese star for window xp download
Hello experts,
Chinese star for window XP download. I want a free download if possible but a shareware download version will do. I hope you will give me the website which is secured and safe.
Thank you
Hello experts,
Thank you
You can download Chinese star windows from this link as you want. http://www.fyxm.net/chinese-star-xp-s.html
Odom Vemus
Hello Jai,
You can download Chinese Star 2006 on the link below:
http://www.cybermania.ws/chinese-star-2006/
This works on Windows XP SP2 and older versions.
You can also try the Google Pinyin as an alternative to Chinese Star which you can get from the link below:
Chinese Star MP enables the Chinese users to access the latest version of most commercial applications. Nathon Halchy, your solution is contentious. The links you provided are very helpful .These sites are safe, secure and also compatible with my XP OS. I wish you and the techyv.com team good luck.
