I am at a crossroads here. I have an express adaptor for asus and I want to replace it. My adaptor at the present is not working well. I want to know the pros and cons of buying another pci or replace my adaptor. I need to have a dependable brand since the one I am using currently is not dependable. Can anybody please help me?
Choose Between Buying Another PCI or Replacing Adaptor
Your question is a bit confusing, what do you mean by express adaptor? Is it the Express adapter that goes into the side of your laptop computer like wireless local area network express cards or mobile broadband express cards? Are you having problem making certain if it's the slot or the adapter itself that is defective? To verify this, try and use a known working express card. See if it works with your system, if it does, then replace the current express card that you have. If it doesn't, then you may need to replace several parts of your computer which may include its motherboard, or a daughter board, the bottom plastics and possibly others.
