Choosing the good one among ‘Dropbox’ and ‘Sugarsync’
I don't know as to which one is best among â€˜Dropbox’ and â€˜Sugarsync’. I have been using â€˜Dropbox’ for a long time and I’m having up to 20 GB storage space in them. I am a satisfied user of â€˜Dropbox’, but I heard that â€˜Sugarsync’ is having many better features than the â€™Dropbox’.
The synchronization with any folder does not interest me, but it is said that the former can synchronize with an Android phone and never allows others to access it. So, it will be useful to me in synchronizing music files and video files to the phone. I had already tried to â€˜Titanium Media Sync’, but it was not working properly. Can anyone suggest me as to which one would be better for this purpose?
Answered By 75 points N/A #108592
Hello Elreda,
Drop box is good. It offers you a lot of storage space and you can end up having up to almost 20 GB of free storage through them. The only issue that it may have is the problem of suspending the file links when you exceed their restrictive bandwidth allowance.
But Sugarsync is even better. It has more features as compared to Dropbox. The Sync feature on LAN helps a lot when it can work, by syncing across for instance an android phone, as opposed to just being any to access it. Sugarsync has also no limitations when it comes to bandwidth use, so there is no problem of file link suspension in it.
You can choose whichever impresses you because both of them are equally good.
__
Lee Hung
