Choosing a Media Player for Samsung Galaxy Note smartphone
As you can see I have a Samsung Galaxy Note smartphone.
As I was browsing through the applications I found several Media Players but I could not decide which one is the best.
So if you can help me and guide me a bit.
What is the best Media Player for Samsung Galaxy Note?
Any help would be appreciated.
Answered By 0 points N/A #173596
Hi Steve!
Indeed there are a lot of media players on the market, but not all of them suit your phone. I have found some that users claim to be among the best. Here you go.
NRG Player is really good, has a good quality sound and a lot of options to suit your preferences. The Poweramp has a few problems on Note, so I wouldn't recommend it. It keeps stalling and refuses to play or to react in any way to your controls.
What I think is best is to use the Double Twist player along with the application "Equalizer". I would suggest to set the preferences to "dance" and "max bass booster" and the sound will be really pristine.
Also, there is PlayerPro. You can try the free trial for fourteen days and see if you like it enough to buy it.
But if you're looking for something more than a music player, MX Player is the best. It is fast and can support really quality videos.
Good luck!
