Thyrza
Posted on - 11/07/2011
Can you please guide me as to which language among ASP.Net and PHP would you prefer to use in website development, if you were a developer? Also, please share the advantage and disadvantage of using each language.
keliy
Choosing the right language between ASP.Net and PHP
I advice you to use asp.net when you are going to choose a language between ASP.net and PHP. The reason is that ASP.net is more efficient than PHP because of the following grounds:
The PHP language is less secure than ASP.net
ASP.NET is faster in performance if you compare it with PHP due to the typing scheme and extra language selection (I could not find the link it was discussed in SO Podcast). You also require thinking that ASP.NET is costly than PHP. You are not required paying software licenses for all servers.
Good luck
There is no right and wrong language between them. Both are object oriented languages so all the object oriented languages have the similar coding technique. Of course there can be performance wise difference between two languages when performing a particular task. PHP falls in to the category of open source development so that’s the biggest advantage I see in PHP over .NET and .NET is owned by Microsoft so you have to buy them. But .NET has more build in libraries than any other language so coding wise most easiest language to handle is .NET
Likewise we can show many differences but overall idea is both are object oriented languages.
