Choosing The Microsoft Lumia Best Phone To Buy.
I need to buy the Microsoft Lumia best phone among all the options available. There may be the best specifications for the minimum price. Which phone should I buy?
It is a tough task to choose the best among the Windows Lumia phones as they are very few in quantities. But, for the meager price of Rs. 10000, Lumia 640 XL Dual SIM tops them all. It has acceptable specifications for the price tag. Then, I will go for Microsoft Lumia 535 Dual SIM at Rs. 5799. Old Nokia phones with Windows OS are also quite competitive. For me, Microsoft Lumia 950 Dual SIM is priced outrageously as there are better Android phones for the same price.
If you’re looking for a Microsoft Lumia phone, try checking Microsoft Lumia 550. The Microsoft Lumia 550 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled on October 2015 and released on December 2015. It measures 136.1 x 67.8 x 9.9 millimeters and weighs 141.9 grams.
It uses nano-SIM card and has capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution. It supports multi-touch. It runs on Microsoft Windows 10 powered by Qualcomm MSM8909 Snapdragon 210 chipset, Quad Core 1.1 GHz Cortex-A7 processor, and Adreno 304 GPU. It supports microSD expandable up to 256 GB. The Microsoft Lumia 550 runs on 1 GB RAM with 8 GB internal storage.
The primary camera supports 5 megapixels with f/2.4, LED flash, and autofocus featuring geo-tagging, touch focus, and 1/4″ sensor size and can record video in 720p at 30 fps. The secondary camera supports 2 megapixels with f/2.8 and can record video in 480p.
It has 3.5-millimeter jack; Wi-Fi 802.11 b/g/n with hotspot support; Bluetooth 4.1 with A2DP support; GPS with A-GPS, GLONASS, and BDS support; FM radio; and microUSB 2.0. It has built-in proximity and accelerometer sensors. The pre-installed web browser supports HTML5. Java is not supported. It runs on removable Li-Ion 2100 mAh battery with standby time up to 672 hours both on 2G and 3G.
Talk time is up to 16 hours on 2G and 14 hours on 3G. It is available in black and white colors. It costs about 90 Euros or about $101.
