Choosing tools to test BI project
If there is anyone have experienced with any good tools to test BI project which is developed by using SQL server Business Intelligence studio 2008. I would be glad if anyone could help me to choose a best one and please also mention the features.
Answered By 0 points N/A #106533
These are some parameters that you should consider in choosing a Business Intelligence tool.
For one, all your functional studies should be done including BICC setup, and where your BI deployment will be located in the BI strata. You can browse the website that sell Business Objects, Cognos, Information Builder,ect. They have a lot of information telling people about their products. Also, find information from “independent” websites such as TDWI.
Another considerations is that define your desirable requirement and if it is necessary. Go to the market and find what is best for you. Find stores that provide you with the most functionality you need and with many features that priced within your budget. I hope this helps.
