Choqok Authorization error on Mac
I am getting this error while trying to run choqok on my system. It says authorization error any help will be appreciated.
Error-choqok Authorized error Details Authorized error
It should open a browser and take you to a permissions page on twitter. When you click 'allow' it gives you a pin to enter into choqok. Also, make sure the localtime on your computer is correct.
Hi William,
Make sure your user id has authorities to run choqok by administrator of the system.
It opens a browser and takes you to a permissions page. When you click allow it gives you a pin to enter into choqok. And set your local time correct on your system.
Hope this works for you.
Thanks,
