Davis Avon
20 points
Posted on - 08/31/2012
I try to use Chrome, installation was smooth with no errors but whenever I try to launch the application there is always an error showing about the Chrome.exe.
Can anyone help me?
Chrome.exe – Application Error
The application failed to initialize properly (0xc0000142). Click on OK to terminate the application.
Chrome exe application error failed to initialize
Hello Davis,
The error that you're getting occurs when there is a corrupted Windows Update in Windows. You will therefore need to debug the program using the following steps:
On your computer click Start
And then right click My Computer
After that click Properties and then click the Automatic Updates tab.
You will then choose Turn off Automatic Updates
After that restart your computer, and then connect to the internet
And then click Start >> All Programs >> Windows Update
Manually update windows after that and then turn On Automatic Updates again.
Carl
