I want to know about a Chrome extension that will allow Speech2Text enabled microphone symbols for text-input boxes on any webpage. I just heard it exists so I want to know where to get its and how it works. Waiting for your replies. Thanks.
Chrome extension that allows Speech2Text enabled microphone symbols
So far, VoiceNote is the most applicable speech2text chrome extension. I’ve tried it myself, it seems accurate but when you pause, the recording stops and the cursor go back to the first line but that’s not a big issue, you just have to record again and put the cursor where you ended. It’s really easy to use and comes in different languages.
After installation:
· Create a shortcut of the application in any location that is convenient for you
· You can also resize the app window in any way you desire
Buttons include:
· Microphone
· Cancel
· New Line
· Capitalization
· Ready
· Remove
· New Sentence
· Punctuation
· Cursor Position
· Smileys
