Efe2cool
Posted on - 11/20/2013
Google Chrome forgets the last used passwords even when saved
I keep selecting the save password option when asked but again all passwords needs to be entered each time
Where can i have them stored
Here are the steps to make Google Chrome save your password for a particular site and Auto-login with the saved information.
Go to the site url
Right–click page info and disable 'Java Script'
Reload page (press F5)
Enter the information (Username and Password)
A prompt will then appear to save password > Click "Save Password.
The auto login extension requires JavaScript to be enabled, so at this point enable Javasctript.
Re-enable JavaScript for the page then reload the page again.
Click on the 'Auto-login' pop up to remember to automatically log into the site every time you open it.
What I would recommend doing is downloading a program called Roboform. Not only is this great for storage of all your passwords, but it also stores addresses, banking info ect. And it also comes with a toolbar for any current browser you're using. Even if Chrome is not storing you addresses correctly, Roboform will store and auto input them for you.
That’s odd. That never happened to me when using Google Chrome even if I store a lot of passwords for a single website. There must be something wrong with the browser itself. Try updating to the latest version first. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your Google Chrome among the applications and click “Uninstall”.
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then download the latest Google Chrome web browser. This link downloads the latest standalone installer for the Google Chrome web browser.
See if this works. If the problem continues, you can use KeePass to store all your passwords for different websites. Go to KeePass Password Safe to get the latest.
