elsietbrown
20 points
Posted on - 09/19/2018
I wanted to surf the Internet as I usually did every day hence, I tried opened Google Chrome web browser. It did not open. I had no idea where the problem was occurring. So, I tried opening it again three to four times after which I uninstalled Chrome. I downloaded it again but it would not progress, and suddenly error code 0x8004070c appeared. Please provide help.
Chrome Installation Error Code 0x8004070c Fixed!
Hi, perform all the things mentioned below to get rid of the bug:
- Press Windows logo key and E key together to open Windows.
- In the window that appears next, type using your keyboard (LOCALAPPDATA%\Google\Chrome\User Data\) in the address bar as it is.
- In the upcoming window, look for a folder named “Default” and name it “Backup Default”.
- Download Chrome in the Offline mode and store it in this folder. The link to download it is specified here: https://support.google.com/chrome/answer/95346?visit_id=636725979778236988-1773901789&hl=en&rd=1#install_win_offline
- If anti-virus or firewall software is functioning while downloading, then Chrome might not work satisfactorily. Hence, you must deactivate this software while downloading Google Chrome.
Thanks and regards.
This error code “0x8004070c” is one unusual error which you may encounter when installing the Google Chrome web browser using their web installer. If you downloaded an installer for Google Chrome and you receive this error code upon installation, it means you downloaded the web installer. Try shifting to the offline installer.
To download the offline or standalone installer, go to Google Chrome Offline Installer download page then download the installer. Next, download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select Google Chrome among the applications and click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo Uninstaller then install the new version you downloaded.
