I just started having problems with using with Windows 7 Pro. Everything was working just fine until yesterday. Now it closes on its own or freezes. Unless I am logged in as Admin then it will work. Is this a Chrome issue, Windows 7 or a hardware problem? Suggestion? Thanks
Chrome Not Working With Windows 7 Pro
Hello, Your Chrome application could have automatically updated, hence, resulting to a conflct with your current system. To resolve this, I recommend that you right click on the Chrome icon on your desktop > Choose Properties > Compatibility Tab > Check Run this program in compatibility mode for: > Choose Windows Vista Service Pack 2 . After applying these settings, open again Chrome. Your Chrome should now function properly.
