Hi!
I just recently installed my operating system and downloaded and successfully installed Google Chrome. I was able to use it for at least few days. Recently, when I launched it, it only shows white screen. Sometimes it shows few information and then it will be wiped away and display again white pages? What could be causing this problem? Can I do some tweaks to resolve this issue? Please provide me step-by-step on how to make my Chrome work. Thank you!
Chrome is not working with Windows 8
Hello Jessica!
We have several fixes for your problem. This could be a cause in your browser or other things entailed with it.
Close all Google Chrome and Running Application.
1. Press and hold “Ctrl” + “Alt” + “Delete” to open Task Manager.
2. Look for processes tabs and check if there’s any Google application running.
3. Close the window.
Clear all the temporary files with your Chrome.
1. Go to Chrome menu and select More Tools.
2. Select the clear browsing data or hold “Ctrl” + “Shift” + “Delete.”
3. Close the browsers.
Changing the settings of Chrome.
1. Right-click in the Google Chrome icon form desktop.
2. Select properties and Chrome Properties window will open.
3. Go to Compatibility Tab.
4. Remove the check from the “Run this program in compatibility mode for”.
5. Click Ok button and restart browsers.
Happy to support you!
Actually, it can be a software issue that causes the problem. So, you can try these alternatives,
Scan the system for any virus attacks.
Verify whether the version of Chrome you installed is compatible with your computer's features. If not, try installing a matching version.
Also try re-installing the software since it can be that the application has not properly been installed in the system.
