Chrome remains displaying the security certificate error message
Hello all,
From yesterday, chrome remains displaying the security certificate error message whenever I would like to attach with my Gmail account and yahoo account.
Also,there is no choice for proceeding anyhow!
But in Facebook login I find the certificate error message along with the alternative of proceeding anyhow as well as clicking to the alternative Facebook opens with no problem!
However,chrome is not permitting any Google website except google.co.in! Also,I have attempted reinstalling. This trouble persists just in chrome.
I have added a few file that holds a number of info about my chrome. Also I am using Windows 7 32 bit.
The site's security certificate is signed
using a weak signature algorithm!
You attempted to reach mail.google.com, but the server presented a certificate
signed using a weak signature algorithm. This means that the security credentials the
server presented could have been forged, and the server may not be the server you
expected (you may be communicating with an attacker).
You cannot proceed because the website operator has requested heightened security
for this domain
Back
Please help me to solve this issue.
Thanks a lot.
Best Answer by Carl Jack
Answered By 15 points N/A #143661
I suggest that you have to uninstall your Google chrome web browser.
1.       Click “Start” button
2.       Go to control panel
3.       Below the word “Programs” click uninstall a program
4.       And find the Google chrome that you have installed
5.       Right click and uninstall it.
Now you have to download the newer version of your Google chrome
Search in Google: latest version of Google chrome compatible with windows 7.
Download it and install in your computer after the installation reboot your computer.
Hope this will help you a lot.
CTRL + Q to Enable/Disable GoPhoto.it
Answered By 10 points N/A #143663
Hello Joyce,
Note that Google Chrome makes use of Internet Explorer's TCP/IP, DNS as well as Proxy Settings. You will also need to check  IE and see if it cannot be able to connect to those sites as well. If that is true then that proves the settings were changed. You will need to do the following:
  • Open IE and then  click on Tools
  • After that click on Internet Options, and then choose Advanced.
  • Reset the settings from there.
Once you have done you will need to check those sites on both Chrome and IE and see if they are working.
Carl
