Hello guys,
"Error message position for date picker is way off the layout."
This error message has been really bothering me. I am running Joomla 1.7.3 and Chronoforms_J1.6_V4_RC2.0. I found in one post that the solution is to check both checkboxes in the required validation. But when I did this, the validation would still not support the program and I have to submit the form directly.
Help needed here.
Thanks in advance.
Chloroforms and Joomla error: validation not supported
Please check this following scripts on your program (Please update your Chronoforms and Joomla to it's latest version maybe it is the one that causing the trouble but if not please be guide the following tips below what may cause the error).
1. Maybe there is a conflict on your CSS with your template, check this by using your web developing tools to know what is going on.
2. Check the JavaScript that you have maybe this is the one causing the error.
3. Check the JQuery loading on your template.
Hope this works for you have a nice day and enjoy your stay.
