Whenever I try running Cinema 4D, I encountered the below error, even uninstalling and reinstalling it with different version does not solve the problem. Can anyone help me here?
CINEMA4D
Application Error! More information can be found under ‘C:UsersJack
RamsayAppDataRoamingMAXONCINEMA 4D
R12_1CC4E3E1V.bugreports..BugReport.txt1After clicking ‘OK scene files will be
saved as ‘_bugreportsf_recovery.jocx.c4d
OK
Cinema 4D Error observed with different versions
Hi Susan
Many Cinema 4D Users are experiencing this type of error, and most of them have no choice but to contact the Maxon Cinema 4D website. But probably, there is a very easy way on how to resolve this problem. A few clicks away and your Cinema 4D will work brilliantly again.
Here is the first option that will surely work:
Right Click Cinema 4D icon on your Desktop
Click the “Properties” > “Compatibility” then click “Run in 256 Colors”
Here is the second solution:
You may also have the “Run as Administrator” then click “Ok” then the program will open.
Go to “Help” then click “Check for updates”. Download all of the updates available.
I hope this helps you to restore your Cinema4D.
