I received an error message while attempting to produce joints for a big protein kill Cinema 4D and also when I try to transfer SPLINE to joints.
CINEMA 4D
Application Error! More information can be found under
Folder path_BugReport.txt
After clicking "OK" scene files will be saved as "_bugreports/_recovert_xxx.c4d
Cinema 4D has encountered Application error
Hello
As you can see in your error report you have a bug report file where you find information what happened to your application.In order to help you we need more information, actually we need your bug report to see what's the problem. I advise you to open your bug report and read faulty information, then contact support of the Cinema 4d team. Also you can post bug report here and we will help you. Regards.
