Cinema 4D installation Error help
I have attempted to install Cinema 4D however it is not installing properly and is showing the below messages all the time let me know what is this error and why it troubls?
Cinema 4D Studio
Cinema 4D Studio
Hello Pedro
I think you are using win7 64 bit platform. The program work only if you run the program as admin because win7 restrict program run without admin privileges due to UAC (user access control).
Run the program as admin ,and it will be ok.
That error is obviously a problem with compatibility. Before installing the program, check the system requirements first and verify that your computer meets those requirements. For Windows, the latest Cinema 4D supports 64-bit Windows 10 only. It requires 64-bit Intel processor with SSE3 support, at least 4 GB RAM, and video card with OpenGL 4.1 support and 4 GB video RAM.
Cinema 4D recommends a video card with an NVIDIA or AMD chipset. For Macintosh, Cinema 4D supports OS X 10.12.6 Sierra, 10.13 High Sierra, 10.14 Mojave, or higher. Cinema 4D is perfect for all 3D artists who want to achieve mind-blowing results fast and hassle-free. It is a 3D modeling, motion graphic, animation, and rendering software developed by MAXON Computer GmbH in Germany.
To know more, visit the Cinema 4D home page.
Notifications
