I was trying to install Circle Dock which is an application for launching programs in Windows. The traditional Windows Explorer is becoming boring that is why I thought of changing program organization in my Windows 7. I downloaded the app and installed but it keeps on popping up an error as shown below. Please help as I tried to download the setup again but still the error appeared.
An application error occurred. Please contact the administrator with the following
Current domain unhandled exception.
Circle dock: Config ini: C:program filescircle dock0.9.2alpha8.2systemsettingsconfig.ini is missing. Please replace the settings file. Circle dock will now exit.
Error: Circle dock: Config ini: C:program filescircle dock0.9.2alpha8.2systemsettingsconfig.ini is missing. Please replace the settings file. Circle dock will now exit.
The reason for the above errors that appeared while installing Circle Dock 32bit application is that this application is compiled in 32bit CD and you may be trying to install it in 64bit windows.
During installation process windows Cd loads GlobalMouseKeyboardHook.dll for 64bit but instead finds 32bit resulting in “format not corrected” exception.
A popup appears Current Domain Unhandled Exception and thus terminates installation. You should check if your window is compatible with this 32bit application.
If you want to install Circle Dock on Windows 7 but you keep getting that error, check that you are installing the latest version and your computer meets the requirements. Download the latest version, Circle Dock 1.5.6.30. It supports Windows XP, Windows Vista, and Windows 7 both 32-bit and 64-bit. It requires 1.2 GHz or faster processor and .NET Framework 2.0 or higher.
Circle Dock
If you don’t have .NET Framework yet, download Microsoft .NET Framework 2.0 Service Pack 2. The homepage of this dock application is here: Circle Dock, but I’m not sure why the latest version is not listed in the download page. I had this application installed on my computer before but had a little problem.
It keeps popping up when I’m playing a game even on full screen that’s why I had to uninstall it.
1....
