What Cisco wireless connection device is the best for the business community?
How small business uses Cisco wireless solution?
Cisco wireless connections for Business use
Hi Mr. Renato Diggs,
Base on my research I suggest to you this Model: Cisco WRV200 Wireless-G VPN Router: RangeBooster. The Cisco WRV200 Wireless-G VPN Router enables secure, reliable wireless network access for your small business. Its intuitive web-based interface allows you to easily set up its features.
Simple Network Management Protocol (SNMP) gives you the ability to remotely manage and monitor the device. Ten IP Security (IPsec) QuickVPN tunnels with a throughput of 30 Mbps give your mobile workers a secure and easy-to-use way to stay connected. As an essential element of your business, this product provides security functions for authentication, encryption, and firewall.
The VPN router gives your business multiple service set identifiers (SSIDs) and VLANs for traffic separation, and enhanced quality of service (QoS) features for improved voice and video quality. With support for wireless QoS (Wi-Fi Multimedia [WMM]) and wired QoS (port prioritization), consistent voice and video quality are maintained throughout your business.
Hope you like it and help with your business,
Cisco Aironet Access Points are a high performance device for secure and reliable wireless connection that is best for business use especially to the business that redistribute mobility apps and to those who are looking for strong security.
It supports standard 802.3af Power over ethernet with multiple input and output technology for a constant coverage. It can be redistributed on a centralized network of branch offices, campus or even on a large enterprise.
The following are the capabilities of Cisco Aironet:
1. Cisco CleanAir Technology
2. Cisco ClientLink
3. Cisco BandSelect
4. Cisco VideoStream
