First Timer
Posted on - 09/12/2011
Hi, I have facing a problem while trying to install Citrix MetaFrame presentation server for windows on a machine where Windows Server 2003 is running,
Installer Information
Citrix MetaFrame Presentation server for Windows can only be installed on Windows 2000 Server or Windows Server 2003 with terminal Service running in application server mode. Setup will now exit.
Need help from any expert ones to get rid of this problem
Citrix MetaFrame Presentation server issue
You have to make sure that the Terminals Server is enabled in order to install it in Windows 2003. Push the start button and go to the Control Panel>Add/Remove Programs> Add/Remove Windows Components. Check the box that corresponds to Terminal Server then click Next. A dialog box informing you that you are enabling Terminal Server will appear. Click Next to continue. You will be asked to choose between Full or Relaxed Security. It would depend on the Citrix MetaFrame that you are installing. If you are not sure, then you can select the Full Security. Click Next to continue and Exit the wizard. You can try installing the software again.
