Citrix server which is the best option for avoid any damage?
I have citrix server it reboot daily. We have same four server & it need reboot everyday. Is there any way to reboot it auto after five to six days? If I change it any problem I going to face?
For citrix server run which is the best option I need to follow regular for avoid any damage?
Answered By 0 points N/A #96035
Rebooting of the citrix server is a healthy thing because it enables the server to recover applications. How to reboot is to run a schedule task that should run on your computer. It should launch a batch file or vbscript to change the log on or the enable command for you. What to note is that if you are using ICA then you will need to use different method from the smart reboot methodology and if the client attempts to use this in xml they will receive an error. So ensure that whatever method you choose your client will be able to access it without errors.
