I am trying to install the 1.1 patch for the test setup time for CIV2. I guess the patch is supposed to update civ2.exe with an updated version, but this is not happening. Once the installer completes, civ2.exe "disappears" and so the game cannot be loaded.
Please help.
CIV2.exe disappears after installing patch
I will suggest that you try restarting the computer after you have finished the installation and then try looking for the application in the list of programs. In case it is not there, try installing the Civ2 application again, that is after you have restarted the computer.
You might also want to check and make sure that the Civ2 patch that you are trying to install is compatible with your computer. If your operating system is a 32 bit, then you will have to be sure that the patch is a 32 bit version too, because if it not they it will not work and it will definitely bring a problem like the one you are getting right now.
-Experttechyv
