Hello experts,
Today I made a fresh install on my laptop with Windwos 7 and when I want to install AutoCAD 2014 Civil 3D this error appeared. I have the original CD and license and I was expected that I could install the program again. Can anyone help me with this ? Why I cannot install ? Should I buy a new cd-key ?
Thank you !
No Civil View Country Resource Kit folders could be found in the following location:
C:ProgramDataAutodeskCivil View2014
Please ensure that you have at least one Civil view Country Resources Kit installed in this folder, then restart Civil View
OK
Civil View Information error installing the program
Make sure the application you install supports your operating system and that your computer meets the necessary requirements for AutoCAD Civil 3D 2014. Unfortunately, installing AutoCAD Civil 3D 2014 requires a 64-bit operating system. Though Microsoft Windows 7 is supported, it requires x64 Microsoft Windows 7 [Enterprise, Ultimate, or Professional]. It doesn’t run on x86 or 32-bit operating system.
You don’t need to purchase a new CD key or license code for the software because it doesn’t have a problem. The problem is with your operating system. I don’t think you will have a problem with the processor because it can run on at least Pentium 4 3.0 GHz processor but it requires 8 GB RAM since it is in 64-bit.
I’m not sure if they have a 32-bit version of AutoCAD Civil 3D 2014 because their website only provides information for the 64-bit but in case they don’t, you can fix it by installing 64-bit Microsoft Windows 7. That means you need to upgrade your whole system because upgrading the system to 64-bit doesn’t only mean changing the operating system. Your entire CPU needs to be 64-bit.
If upgrading your system to 64-bit is not an option, install AutoCAD Civil 3D 2013 instead because it supports both x86 and x64 operating systems.
