Classic pong sound still reminds me boyhood, need to collect some.
Hi guys
Any of you know where I can download the original sound effects from pong? I'm making an online version of pong and I need the original classic pong sound.
Hi guys
You can try on the link below, but you need to create an account to be able to download the sound file.
You can also go to this forum and download the pong sound in ZIP format.
Hi Coshaun James,
You might also want to try Audacity where you will have two options to get a copy of the original sound effects from Pong:
1. You could play the samples and record them as .MP3.
2. Or you could export the recording as .MP3.
You could also install and play Classic Pong through Google Play. Hope this helps.
Murakami Wyatt
