I am using Internet explorer for browsing using Window 7. I want to Clean up Internet explorer profile or temporary internet files which is stored in which is stored in temporarily in computer but I don't know how I clean up internet explorer profile like username Password etc. If any one know how cleanup that all things please give me any procedure or any web link from which i can solve my problem.
Clean up internet explorer profile
Hi Harvey Logan
I searched a solution that may help you solve your problem. Open your Internet Explorer:
1. Seeing Menu bar, Just click on tools and locate for the internet options and then click it.
2. Looking at the Internet Options Tab: Stay in the General tab and then go to Temporary files which are located just behind the Home page.
3. Click Delete files, Delete Cookies.
4. In the history Tab just also behind Temporary files hit Clear History.
5. Click OK, now all the usernames and password that was been saved on the internet explorer is deleted.
I would like to share to you on how to easily clean your internet browser, registry clean-up and also optimize your system. This program is a freeware, you can download the software using this link http://www.piriform.com/ccleaner/download/standard.
After downloaded the file, install it to your pc and just follow the procedures on how to clean-up your system. I hope this can help to solved your problem.
Thank you.
