Cleaner for blu ray case 3d
What should I use to clean my blue ray case 3D? My niece got some of my cases stained with her spaghetti. I cant removed the red stain with water. I am afraid to use other solutions. I need some advises.
Hi Alexander,
Usually for cleaning blue ray cases, you just have to use soft cloth. You may use a little alcohol with the soft cloth, but if you're hesitant to use solutions such as isopropyl alcohol, I would advise you visit the nearest electronic shop in your area. They may offer you specially designed clothes and solutions used for cleaning blue ray. You may also check amazon for these type of clothes and solutions.
Hope this helps.
