Hello experts!
From the start of lifetime, Cleanser ISO 6.0.691 displays the following errors just under AcronisLogo:
ERROR: Unable to locate IOAPIC for IRQ 64
ERROR: Unable to locate IOAPIC for IRQ 65
ERROR: Unable to locate IOAPIC for IRQ 78
Loading, please wait. And it’s all.
Does anyone have any Idea? The Server is a DELL PowerEdge 2950 controlled with a SAS 6i-Controller.
Thanks in advance.
Cleanser: Unable to locate IOAPIC
Dear Carla Santos,
According to the error message you got ERROR: Unable to locate IOAPIC for IRQ, what about trying the safe mode version of Acronis cleanser as the full mode might require updated drivers to support your hardware. You might also download and try the bootable media from Acronis with your account and boot it with the parameter acpi=off.
To enable it press the f11 button when the media finishes loading and enter it in the prompt window. You can download the bootable media from this link: https://kb.acronis.com/content/4828, the link has a plain explanation of how to download it using your web-account.
Hope this may help you.
Best of luck.
Safe Mode is the solution to many problems. Have you tried that? Maybe the Full Mode version require the drivers to be updated to support the hardware. If the problem consists contact to ''Acronis Support'' at this url ''acronis.com/support'' to submit a report to correct your drivers and solve your problem.
