Cleansing and optimizing PC using CCleaner 3.19
I’ve just downloaded the latest version of the CCleaner and have installed it in my PC.
How does this software deal with the log files and settings left behind by the previously installed software?
CCleaner is the most trusted software and widely used in tech. community . Download this software (for free) in our computer will be profitable for u. It can boost up your PC and make it faster by removing or deleting log files and other installed or temporary files. This kind of files store in your PC everyday and fill your memory when u work. As a result, day by day your PC becomes much slower .
But using this CCleaner will help u to wipe out them fully and make your PC faster than before. For doing it, just open this software and left side u will see the types of files u want to wipe out. Just tick them as your desire and finally click Run
cleaner and in a moment u will see the work will be done.
So you already have the latest version of CCleaner 3.19. Temporary information can be obtain by installing and removing programs, browsing the internet and more. And these information will spread into your hard disk drive. Also, your Registry wherein all the databases is stored will be left with specious entries that refers to a long list of deleted directories, links to applications that is not present and an attempt to open the startup applications that is already deleted from your computer.
CCleaner is capable of deleting unwanted and temporary files, browsing history, log files and the old settings from the previous software you installed on your PC. It is a registry cleaner and an optimizer which can find and remove database entries on your computer. It comes with the security tools like data eraser to ensure that your files are completely removed from your system. After running CCleaner, your computer will run fast and improved on performance.
Thanks for reading.
