Clear BlackBerry Curve 8520 Browser
How can I clear the cache on my BlackBerry Curve 8520 browser?
I tried it in the Menu key and Cache Operations but it did not work.
I am telling you the solution step by step :
1. At first you go to your mobile's home screen. Then you click on your browser Icon.
2. Press then "Menu" key.
3. Then click "Options"
4. After then please click "Cache Operations"
5. Many Cache Type will come. Beside a cache type, Click  "Clear"
6. Then Click on the "Escape" key.
It's Done. Thanks.
There are been a lots of questions raised on the basis of BlackBerry Smartphones , i been using BlackBerry for many years and its my favorite . The question here is clear you want to clear the cache of your BlackBerry Smartphone's browser ,Â
Just follow my steps ok , just go to options while you are in your browser and then click cache operations and you can see a dialog box in that click clear cache , click yes when prompted and you are done . Your cache in BB is cleared .Â
Hope that solves your case .Â
Lesten Pasio
IT Expert. .
