Clear the history of your internet browser of 6 , 7.0
If we browse the internet normally on our hard drive  each of the items we have viewed will be saved.
If you are a user of  micro soft internet explorer 7.0, to view history click Tools menu – insert options – settings –  under browsing history – click view files
To delete a history
Press CTRL+shift+DEL To open the browser
If you are a user of Microsoft internet explorer 6 click Tools – internet options and click delete.
Best Answer by Anan take
Answered By 5 points N/A #162885
Dear,
Every internet browser saves record of internet browsing. This record helps us to find previous work documents. Sometimes miss use of this document can be dangerous. It is better to delete the history after browsing each time in a public computer. For a private computer history delete process is not so necessary.
For more safety measures user should delete history.
Thank You.
Answered By 0 points N/A #162887
If you are using Windows Vista or Windows 7:
Click Start > Control Panel > Network and Internet > Internet Options.
Then Click General tab and then under Browsing history and click Delete. Select Delete all and click yes.
You are done.
If you are using Windows XP:
To delete “Internet History”:
Go to Start->Control Panel->Internet Options.
Click General tab, under history section, click clear history.
To delete the “Temporary Internet Files”:
Go to start >Control Panel->Internet Options.
Click General tab, under Temporary Internet files section;  click delete files then check “Delete all Offline content” click OK twice.
You are done.
Note: Same procedure applies for all versions of Internet Explorer.
