BensonK
Posted on - 11/01/2011
I need some clarifications before I go ahead with my plan. Assuming that I have my audio device on a controller and then I give it a full sub bandwidth, what sub ports should it run on? What are the sub controllers on my mob? Secondly, if I use my mouse and keyboard on the sub 1 hub, will this decrease the bandwidth consumption? If it does, how will the response be? Lastly, does my sate/sub port share the bandwidth or does it have its own?Â
lee hung
75 points
Clear instructions on my hardware and the ports to use for bandwidth
Hallo Ben,
If you device has several network ports but they are of the same type, then they should all work well when used for the internet connection, unless they are different ports set with different specifications when it comes to bandwidth usage.
The keyboard will not have an effect on the bandwidth consumption when connected to the sub 1 port, because its usage does not really depend on the internet connection. Whether the there is an internet connection or not, you should still be able to successfully use your keyboard.
Hope this will help you.
__
Regards
Lee Hung
