Clear the Internet Explorer 9 Cache
Once your browser is open, click the gear at the top right to open the settings menu.
Then, select Safety and Delete Browsing History…
Or, optionally you may simply press Ctrl-Shift-Delete to open the Delete Browsing History window.
Choose what to delete
Select Temporary Internet Files. You will also need to uncheck all the other boxes, especially Preserve Favorites website data. This option makes the window also delete objects from websites in your Favorites folder, which is necessary to completely clear your cache. Click the Delete button near the bottom of the window to perform the operations (i.e. clear your cache by deleting temporary files).
Your computer will work for a moment, and then the process will be complete.
You have successfully cleared Internet Explorer 9's Cache!
In internet browsing or web browsing, the term “cache” refers to the data or files stored temporarily on the computer or device. In mobile handsets, whenever a user encounters difficulty in browsing the web this can sometimes be fixed by simply clearing the cache of the Smartphone.
When this is done, it totally clears or deletes the browsing history or the information about the websites visited including cookies.
In computer, when deleting or clearing the cache of the web browser like Microsoft Internet Explorer, you can do this by going to “Tools” then “Internet Options”. In “General” tab under “Temporary Internet files”, click “Delete Cookies”. Then under “History” still in “General” tab, click “Clear History”.
This deletes the browsing history of the web browser. This process is very similar with other web browsers.
Many thanks fellows, for your ratiocinations. Avowedly I know that by deleting or clearing the cache of the web browser I can make my PCs perform speedy but this free and easy system was hard for me because I did not know this process.
Guys, by analyzing your solution and succeeding your step by step technique now I am able to successfully clear Internet Explorer 9’s Cache! I can now open all the sites easily because I learned something from Sharath comments which is very understandable.
Thanks all as well as Techyv too for giving space for this post.
