Clicking Sounds In my CPU
What would I do if I always hear clicking sounds in my CPU? Is it a sign of malfunctioning hardwares?
If there is a clicking noise I would seriously recommend having the hard drive looked at, that is usually the result of a hard drive on its way out. If you want to keep the data on the hard drive, you should look into a new drive now before the drive fails.
Noise can also produced because if any dirt is there in the fan, and if the machine is not getting adequate cooling. First of all you open the cabinet clean away the dust. in bios you can have some features like cool and quite technology. so in bios you can turn on Q-fan control that will reduce the sound of the fan to a great detail, otherwise check how many fans you have in the cabinet and you can have a ventilated cabinet
Thank you Cnales Semilla and Rosales blair. Thanks for the help. I cannot figure out what's wrong so I just hired a technician. The problem was on the hard drive. Thank you TechyV.
