Client Access License on Devices that has NFS Server Installed
Do we require any additional client access license regardless of the device* or devices on which the NFS server is installed ?
No, you don’t need any additional client access license regardless of the device on which the NFS server is installed. NFS server always supports unlimited client access.
NFS Server version 4.3 on Windows 7/2008/2003/2000/XP/Vista Platforms now supports
1. TCP protocol for network connection
2. Cross domain file sharing
3. Alias naming for exported directory
4. File name character mapping between Unix and Windows Systems
To set up an NFS Server, you need to follow the following steps:
1. Edit the /etc/exports configuration file to get NFS to function. The file entry should look like this:
2. With the server configured, NFS could be run simply by rebooting your computer.
3. Verify that NFS is running by using the rpcinfo -p command. This should appear:
Hope this helps.
Murakami Wyatt
Notifications
