Client denied by server configuration
I am using Tigase server. I tried to setup proxy_mod of apache to forward HTTP traffic from AJAX Jabber client to the Bosh component. The same was working fine with GENTOO server. It was a system based on the Debian and the proxy_mod didn't work displaying the error messages in the log file as mentioned in the image. How to resolve the issue?
Answered By 0 points N/A #85724
The problem with Tigase is when you to are trying to make it realise that change has occurred. It is not able to handle large traffic without support from other servers. What can really solve your problem is to consider having a MS MQ server to help support your traffic. The solution really depends on issues like traffic flow and other related details.
Another option is to consider starting it up as anew thread in the start. Which I am sure will do a constant check for you. But try the earlier option before going to this because the later option is short lived the upper option is a long term option which will help you for such a long time.
