Clone update both global and local inventory
I need certain clarifications regarding my concerns. Will the rapid clone update both global and local inventory or do we have to do it manually? How can I reduce the patch time? Kindly provide briefing about select statements in sub queries.
Best Answer by Molina Kevin
Answered By 0 points N/A #107480
Because the main data source methods transactions, the particular ARCH method for the primary databases will be poised to convey the redo info towards the standby. On standby, one or perhaps more RFS methods are employed to get redo information and MRP process can be applied the particular remake info for the standby. The primary data source even offers the Fetch Archive Log (FAL) method to render a client-server mechanism regarding transferring archived logs for the standby following communication loss between the primary and also stand by for automatic gap resolution and also resynchronization.
Constellation Stairway:
This section offers a step-by-step book of operating manual how to create 10g Data guard. Additional information has been provided as notes to intricate or explain type A point. Just about almost most steps proven have been tested up about a Linux system nix.
http://dbafix.blogspot.in/
Regards
Jackson D
Answered By 0 points N/A #197461
Hi. There is one Local Inventory per ORACLE_HOME. It was located inside the ORACLE_HOME at $ORACLE_HOME/inventory which contains the information of the patch level for that ORACLE_HOME. Global Inventory is the part of the XML inventory with high level list of all oracle products. As for your question. Yes, Rapid Clone can and will update both Global and Local Inventory, accompanied by some information in doing so, you do not have to do it manually. Just make sure that inventory exists with runInstaller/show Installed products. You can reduce patch time by, merging patches via admrgpch, you can use various adpatch options, and by using defaults file.
