Clone Windows 7 Hard Drive?
Clone a Windows 7 hard drive is a productive way to backup the data so that the user can increase the hard drive capacity through cloning. So how to manage this while cloning is an arousing question.
Cloning is not so easy as Windows built-in Disk Management won't allow this process. So there is a need to install a free app with various functions. Keeping this in mind, MiniTool Partition Wizard is a recommended app for this purpose.
Before you do: to clone and replace the hard drive in Windows, the following steps must be executed.
1. Attach the hard drive to Windows 7.
2. Download and install MiniTool Partition Wizard free edition.
3. Back up the data.
Step 1. Choose the hard drive and Select "Copy Disk Wizard".
Step 2. Click "Next "on the next page. Step 3: Choose source disk to copy.
Step 4: Choose" clone to the hard drive in Windows 7".
Step 5: Analyze the changes you have made. You can customize using Copy options.
Step 6: Click "Finish" to go back
Step 7: Click "Apply" to confirm details.
