Hi experts,
 I just downloaded and tried to install Close Combat but I received an error message saying ‘No scenario files found. You need to reinstall Close Combat’.I selected manually the sound output but the error displayed. How can I fix this issue? Please suggest me with a proper answer. I would be grateful to you. Thanks in advance.
Close combat error.
No scenario files found. You need to reinstall Close Combat.
Close combat received an error
In this case I think that the game that you downloaded is incomplete or it has files that are missing. Delete this version of the game and download again because probably there was problems with the internet connection. If the problem persists it`s a problem with the game and you have to download another version from another site.
Hi Timothy,
The possible cause of this error is that you have missing some files/ data. Perhaps you should install it with your anti-virus and firewall turned off. Occasionally anti-viruses block some file/data which prevents the program to install. Or you might also try to change/ fix your registry.
I hope this will help you.
