shaneso
Posted on - 10/31/2011
Hi everyone ,
I am thinking of using cloud computing software with a full service. I want to know if how can I recover or transfer my information to another vendor if something happen or the vendor can no longer provide the service for my ecommerce business.any help with that
Thanks
lee hung
75 points
Cloud Computing Software with full service
Hello Shaneso,
I will suggest that you try using the OpenStack cloud computing software, which is available under the apache 2.0 license. If you get the licensed version then you can be sure to use full cloud computing services with the application as opposed to the free version that may have some limitations on the service that you can use.
The application can be run by anyone, and anyone can built on it and also most importantly as you have said in your question it will allow you to submit any changes back to the project.
You can give it a shot and see if it gives you the services to satisfaction.
Hope this helps.
__
Regards
Lee Hung
hi
Cloud computing provides hosted services over the internet.You are asking about the security issues concerning
cloud computing.Even many companies are changing to cloud,because of high speed internet and a weak economy .
There are two type of cloud service,private and public.A public sells service to anyone in internet,
but a private is a data center that supplies hosted services to a limited number of people.
Major concern for most enterprises about cloud services is its security as you asked.
There are a lot of things to be kept in mind while opening a cloud service.and some of them are
should have security needs taken care by service providers,monitor ad migrate known vulnerabilities,
use remote management options like VPN,understanding and resolving any IP-related threats,etc.
So you could start a cloud service by keeping in mind all these and have make a god study about it.
shaneso
Cloud computing software sounds secure. It can run faster and get my applications up with easier manageability and less maintenance. The provider ensure that it is adequately secure, restricted and documented. Cloud providers assure that i can access to my data and application regularly.
