Cloud Computing under Linux Red Hat
What type of machine can I use in purchasing cloud computing under Linux Red Hat Enterprise and how much it will cost to avail it?
Red Hat Enterprise Linux knows their market. They knows their customers well and to that, they knows your needs b offering subscriptions and identifying your needs.
They have this feedback portions, where they ask valuable information from the customer on what to improved in their products and services.
You will need the following machines to work with Red Hat Enterprise Linux such as the following listed below;
Desktop self-support probably cost you $49/machine
Workstation self-Support probably will cost you $179/ machine
Workstation Standard probably cost you $299/machine
But this rate will depends on what you need, in a yearly format. You can subscribed for a yearly basis and or in a longer 3 year contract.
Red Hat Enterprise Linux Server self-support cost you differently from other standard services for cloud computing. A server self-support up to 1 guests will cost you $349/socket-pair for 1 year subscription, but will save you much money if you go for 3 year contract of $995/socket-pair.
On every server and business needs for Icloud, cloud computing will cost you differently. However, you will get the best of it because it's security is so robust, protection against exploited security flaws are in works daily, real-time. It has the highest grade protection sing SE Linux security features, designed from attacks and full transparency. It also has this smart card authentication support, that uses an encryption code when logging in.
