 Which cmdlet should you run, using Ms Workplace Perspective, on the consumer network if you need to find out immediately whether customers can log on to your Address hosting server? To be able to increase your body system protection you choose to apply darkness account details. What command should you use?
Cmdlet allowing you to immediately see customers’ login ability?
The cmdlet logs on to the mailbox that you specify using the credentials of the account with which you are logged on to the local computer
You need to be assigned permissions before you can run this cmdlet. Although all parameters for this cmdlet are listed in this topic, you may not have access to some parameters if they are not included in the permissions assigned to you. To see what permissions you need, see the "MAPI connectivity" entry in the MailboxPermissions topic.
The cmdlet that you should use is the Test-MapiConnectivity, which confirms the functionality of server. In addition, it logs on mailbox, which you have identified, and recovers a list of items and data in the inbox. While someone is getting into the systems, the cmdlet checks 2 vital protocols that are used when a customer logs in the mailbox: the LDAP and them MAPI. Throughout verification,Test-MapiConnectivity authenticates MAPI server, DSAccess- Directory Service Access, and Exchange store.
