Cmdlets For Quest AD Tools PowerShell On Windows.
I am using the Quest Active Directory for Windows on my computer. I need to know where I can get the CMD commands package for Quest AD tools PowerShell. Please help.
The short CMD commands for the Active Directory components are called as cmdlets. You can directly download the package for all the cmdlets of the Quest Dell/Active Directory PowerShell from the official website. The syntax for the cmdlets is as follows.
• Parameters – CMD parameters.
• Pipelines–pass object
• Objects
• Looping commands for iterations
• Redirection – spool to file
• Script Block–collection of commands
• Tab competition
• Transaction
