I have a 10 mega-pixel camcorder. No name on it not counting "Computerized Movie" running in the side. Every time I associate it under mass space it peruses the camera splendidly as a mass space device (MASS Space (I)but when joining it under pc zoom lens it lack the capacity to recognize the driver for "Mentor DSC". Any assistance? Are coach DSC windows 7 drivers needed?
Coach DSC windows 7 drivers
Hi Helenmarmstead!
You can set the DSC-s70 with a number of significant improvements.
Use SDC-s70 supports manual focus from 0.1m to infinity in 13 steps using the jog dial.
Images can be recorded in JPEG or GIF compression formats, or TIFF for uncompressed.
You can set the white balance option.
NOTE:
Don't put your camera near a window or outdoors may because of direct sunlight its lack the capacity.
