evelozano
10 points
Posted on - 02/22/2012
Hello experts.
When I opened Spyware Blaster 4.4, I got the following error message:
Error while unpacking program, code 2. Please report to author.
Then, I uninstalled and reinstalled the program, but I am still getting the same error code. Need your help to solve this. Thanks.
“Code 2” error while opening Spyware Blaster 4.4
Hello Evelozano. This problem usually happens whenever you try to perform Microsoft Windows updates. To solve this problem, you need to reinstall your program (the antispyware). The thing which you need to do is to update your antispyware. Start by uninstalling your antispyware. Go to control panel, click the programs (uninstall program). Then go to the antispyware vendor’s website, then download the antispyware. Reinstall the antispyware following the given guidelines. Before uninstalling, make sure you write the product license). After that, perform a smart update. After this the problem will be gone. Try restarting your computer and try to check once again.
