whopperman
10 points
Posted on - 02/16/2012
I am working with my Code Composer Studio, and the license gives me the following error message.
I already hit the Help Menu in Licensing Options, and I also tried to browse the license Texas Instruments provided me.
But when I hit OK the error shows (this when I am debugging):
Error
Exception occurred during launch
Reason:
No such feature exists,
Feature: CCS_CONNECTION_ALL
License path. C:Program FilesTexas
Instrumentsccsv4licenseTMDSCCS-HWN01A-v4.0.lic;C:Program FilesTexas
Instrumentsccsv4DebugServerLicense*.lic;C:trlicense;FLEXnet Licensing error:-5,357
OK
Need your help.
Code Composer Studio errors out when debugging
The problem you have stated is not actually with your 'Code Composer’ licensing, it is a FLEX net licensing error.
Solution 1: If you have bought this software ask them whether you can use it with current configuration, or it is just available for a specific configuration.
Solution 2: Uninstall the code composer and reinstall it with the configuration you want to use, more specifically the processor model you are using with.
Solution 3: You can buy the Code Composer license again or use the evaluation version.
Hello!
This problem is called Flex Net licensing error. The problem is not for installing “Code Composer” software licensing.
You can fix the problem easily.
First, you have to know from your software provider whether it can be used with another configuration processor or with a specific configuration.
You are recommended to use Code Composer’s latest version with the license key.
If there are still problems, you can recover your system with the last working configuration you have used in your PC.
If it doesn’t fix the problem, do a clean install of Windows.
